SPOOL32 ERROR MESSAGES
CAN ANYONE TELL ME HOW TO PREVENT OR AVOID SPOOL32 ERROR MESSAGES, PARTICULARLY ON STARTUP? I HAVE TRIED PURGING MY PRINTER BEFORE SHUTDOWN BUT I STILL GET THE ERROR MESSAGES ABOUT ONCE EVERY THREE OR FOUT STARTUPS
BOB ROBERTS
RE: SPOOL32 ERROR MESSAGES
> BOB ROBERTS
I found if you untick 'enable bi-directional support'(in printer settings) then it sorts it out.
Bill
Brickinit
> BOB ROBERTS
bob,
stop shouting
malc :rollsmile:
Claremac
I'm getting Spool 32 errors as well at odd times like when I open Paint Shop Pro. Also when I try to print something I always get 4 Spool 32 errors but I cancel them and the print goes OK. Where is the "bi-directional support" setting please as I can't seem to find it.
Regards
Clare
Phantom_Flan_Fl
I did find this on the Microsoft site.
Don't know if it helps.
Claremac
Dave, I did find that site but can't work out if it's relevant. The errors I get aren't specific they just say "Spool 32 error in <unknown>" and I can still print OK. Any thoughts?
Regards
Clare
Phantom_Flan_Fl
Have you thought about the manufacturers website??
Sometimes if it's a known occurence they have a solution on their site.
What make/model do you have?Huh
Claremac
I take it we are talking about the printer in which case it is an Epson 890.
Regards
Clare
Phantom_Flan_Fl
Had a look round for you, but couldn't find anything - sorry.
