Running a MUD on my computer
PhillipH
heya
ok ive set up a mud on my computer (multi user dungeon) and i can connect to it myself of my own machine and everything is great.
however - nobody else can connect to it.
is this a dns problem? or dont plusnet allow such things?
if i need to reconfigure my router i need help with this.
thanks
PhillipH
RE: Running a MUD on my computer
ok well it appears that it is indeed a adsl problem.
if i connect using my dial up - other ppl can connect to the mud happily.
so what is it i have to do wif my adsl for that to accept ppl connecting to my port 4000 ?
thanks
This is that your router needs configuring.
With dial-up, your computer is directly conected to the internet, and any connection attempts go directly to the ocmputer.
With a router, unless the router has some form of rules, specifying where the connection should be forwarded to, then it drops it.
Read the documentation that came with the router (possibly on a CD in PDF format) regarding, how setup a forwarding port.
It may also help is you post the make and model of the router, so that others can post instructions.
You will have to setup port redirecting on the router to port 4000 - if U post the make and model as suggested then people with experience of your model will be able to help.
Find a job you love and you will never have to work again?
Sweetkid
