Raw Webstats - not being created?
Hi guys
Just a quick line to say that I have notcied that the Raw Webstats have not been posted in my domains log folder as they normally are. I have raised a ticket with F9 but just thought I would let you all know in case people rely on them.
FYI the actual 'webstats' facilty does show activity on the days I trawled my sites (proof that it has been used) yet not Raw Logs have been created in the logs folder.
On another note, telneting to crofters and using VI yesterday I found two annoying issues that were not there prior to CGI change over (I think),
1. Cursor key do not now work in VI (I have to use ghjk!) - they worked b4
2. CGI code is no longer colour coded, which was dam useful!
If anyone has any suggestions on correcting points 1&2, or can suggest a much better way for me to interect with crofters I am all ears.
Many thanks
C
