RE-TV OUT
cannylad
RE-TV OUT
I would like to thank Ivan Ratoyevsky and Big Al, for the help on the TV Out question I put on this forum.
I purchased the Radeon 7500 and it does exactly what I want. I can now play a movie file on my computer directly to a video recorder.
Eric
RE: RE-TV OUT
> Hi,
> Thanks
> Eric
Thats a great card isn't it? The only problem I've found with it is that with Windows 2000 you can't do a true dual monitor setup (i.e. different resolutions on each monitor), instead it basically outputs a very wide image, but it's still all good.
RE: RE-TV OUT,So Pleased !! Ivan
> Hi,
> Thanks
> Eric
Hi Eric,
Hay that's great mate I am so pleased you got the result you had wanted from the start. I learned a few things too cheers. ENJOY ENJOY!!
Ivan
RE: RE-TV OUT, More Detail Please? Ivan
> Hi,
> Thanks
> Eric
Hi once again eric,
I would really like it if you could describe in detail what you've done and how you've done that (inc the kit used & purchased) so I can help other users in future.
Cheers Ivan
