Port Forwarding
Port Forwarding
How do I set up port forwarding? I have a 3COM router, but I cannot set up my own FTP server. I have been told I need port forwarding.
1 REPLY
RE: Port Forwarding
it should be in the manual.
normally its like setting up a ip for which all calls to a port will respond.
e.g. if you have a comp on your network at say 192.162.1.4, then you wold set that up to be okay for port 21 in your routers nat settings.
see if its addressed in the index of your manual.
