Pop Up Blockers
Pop Up Blockers
Would appreciate advice on which is the best to download.
Paul
Pop Up Blockers
google toolbar
http://toolbar.google.com/
stops all popups and rembers which pages you want popups to appear also grate for searching a web page for words, just type the word(s) in the space then over the far right click the word u justed typed and it finds that word on your web page.
Stop The Pop Up's
Hello,
I have tried several pop-up stopping programs (freebee software) some good and some abit limited. I am currently using a free pop up stopper program which I can highly recommend to you if your intrested:- URL for stop the pop up program. Its small & very very easy to use and extremely effective and the website even allows you to test the program is working correctly. Its great for a pop up free life!!
http://www.sureshotsoftware.com
Best Regards :lol:
Ivan
Try 'Crazy Browser'
Hi, I use Crazy Browser (http://www.crazybrowser.com/) which is free. It has pop-up blocking, tabbed browsing etc and comes with ability to turn off javascript, active-x etc per page as well. Cheesy
Browsing Securly
Just an addition really to this thread, if your especially looking for a high quality internet browser that is scrochingly fast and has extremely high levels of security then I can highly recommend the browser "NoTrax" I would give it 10 out 10 brilliant.
http://www.heidi.ie/notrax/
Ivan
Pop Up Blockers
why not use firefox which has built in popup blockers etc and its free
also there are programs like adaware, also good software to use is spybot search & destroy and spyware blaster.
most of the toolbar addons are full of spyware and that includes the google toolbar..
A word of warning about Spyware Blaster
Hi woodviews,
Yep! agree with you about FIreFox Browser I downloaded a copy and have been testing it, I would happily recommend this browser as a high quality alternative to MS IE6.
**HOWEVER A WORD OF WARNING ABOUT SPYWARE BLASTER!!
It is my direct experience that Spyware Blaster is useless and it fails to work completely when it really matters i.e. when your system is attacked or attempted software try's to install itself. On several occations SB failed miserably to stop a number of spyware programs getting into my system. Fortunately I was on the case extremely quickly and was physically able to remove the offending files and adaware found the other files and registry keys that had been installed.
Therefore based on my own experience I wouldnt put ANY trust is spyware blaster, it may lull you into a false sense of security. Finally SB takes up physical space on your HDD and memory resources, so its even more of a waste. I removed SB after the third failure and instead have locked down my OS services and IE6 settings and have had no problems since.
Dont trust Spyware Blaster to protect your system, it sounds great but doesnt work when it matters most. Tweaking your OS and IE6 settings is a far more reliable approach.
Ivan
Pop Up Blockers
i use it inconjuction with spybot search & destroy - i also use adaware which blocks a lot of stuff
as for spyware blaster I agree its only works when you run the scan and doesnt really stop anything, another program I have used for trojans anti-labs ghostbusters which was given away free by pcformat
Pop Up Blockers
Assuming you're running XP, service pack 2 does the job nicely, plus introduces a load of devices that stop alot of spy/malware getting in.
Don't worry too much about all the hype that it breaks stuff. Most issues are firewall related and easy to sort out. There really is very little that the home user needs to worry about, providing they have a moderate spec machine.
hmmmm
Just use Firefox, it's a billion times more secure for a start, and the popup blocker "works"
