Please take this quick survey
I am collecting data on how well people estimate the size of angles - not the most interesting survey topic in the world, I know, but I'd really appreciate it if you could spare just a few seconds to fill it in:
Take the Survey!
It won't take long, I promise!
Thank you.
Of course, it is a survey hosted on the PlusNet CGI space making use of the provided MySQL database.
Phantom_Flan_Fl
Got 1st and 3rd correct, 10 degrees too low on 2nd.
I failed on all three, but only by between 5 and 10 degrees
Chilly
Chilly
Mine where wrong wrong and wrong, although I was pretty close on all of them.
Yes me 2, I was within 15 degrees on all three.
I was pretty close on all but the last one :-( but hey it's been years since I did maths and angles lol
Alecto
Three comments on the survey:
1. It's demotivating to be told you are "wrong" when you're only a few degrees out and, for all practical purposes, near enough. I can't see many people getting them exactly right apart from the first one.
Unless of course they go back and do it again when they've seen the results!
2. What on earth do you want to know for?
3. Are we going to get to see the results and what you deduce from them?
:roll:
Good points.
1. I'll change the wording.
2. I set up this survey mainly because it is part of a course in classical statistics.
3. Yes, you will get to see the results. In fact you can do that right now:
http://cgi.corfizz.plus.com/Fizz/Survey/Results.php
The final deductions will also be posted, hopefully.
Just had a look at this, but the first angle doesn't show.
Julie
Can't see the first angle either .
I am using firefox btw.
Wouldn't use anything else (well here anyway)
Very odd. The images seem to have vanished from the face of the server. I'll re-upload them when I find them.
I'm not collecting/analysing the data any more, by the way.
Julie
Ok no problem Smiley
