Playing .avi files?
mikeshe
Playing .avi files?
What do I need to play the .avi files, please?
Mike
RE: Playing .avi files?
You should be able to just play them in Windows Media Player.
Maybe the avi you have is encoded in divx? You could try downloading the divx codec at www.divx.com
And then load it in Windows Media Player and play it again..
mikeshe
Yep, DivX it was...... all okay now. Thanks for the help.
Mike
Teatime
You might also want to get a copy of Divfix - it's free and very useful for recreating the index for partially-downloaded AVI files so that they can be viewed using Windows Media Player.
http://www.divx-digest.com/software/divfix.html
Ivor
mikeshe
> Ivor
Thanks Ivor, another good piece of info.
Mike
