Photography
Photography
Can someone help.!!
Can i turn a picture taken on Slide Colour film into a normal print or is that it .
if so how do i do this , do i take it to the local lab and they can produce a print from the slide.??
Help .
Vince Dunne
bjanda
RE: Photography
> Can someone help.!!
> Help .
> Vince Dunne
A local high street processing store will probably be able to make a print from your slide. Try Boots or Jessups etc.
If you have access to a slide scanner or adaptor for a flatbed scanner you can make your own prints.
Hope this is of some help.
RE: Photography
> > Can someone help.!!
> > Help .
> > Vince Dunne
Other option is for you to have the slides but on CD.
Only worth doing this if you have plenty because a CD will hold an awfull lot of pictures.
You can then print out the ones you want with a Inkjet onto decent quality paper.
Regards
