Peer2Peer Problems
okmbok
Peer2Peer Problems
I am getting rubbish dload speeds woth edonkey.
Does anyone know if Force9 limit the bandwidth on popular TCP/UDP ports used in p2p??
I have heard that some isps do this?
Plusnet Staff
Plusnet Staff
Peer2Peer Problems
We don't have an traffic shaping or throttling in place that would cause any slow speeds with edonkey.
It's more likely the people you are downloading from have slow upload speeds causing the slowdown.
Peer2Peer Problems
don't forget with programs like edonkey, emule, kazaa, etc the intial download can be slow.
the reason being you may only be connected to one person, so you getting it all from them, the more you connect to, to download the faster it will be.
and remember when you on the net, with these types of software, people can retrieve whatever you downloaded via their packages, which will eat into your bandwidth.
regards
Mike
Peer2Peer Problems
Have you installed SP2 within windows? Is this a recent thing?
