Peer2Peer Help
Peer2Peer Help
hi could anyone tell me what does plus net block you from using peer2peer if you have previously downloaded to much stuff from there the previous month thanx for your help..
Peer2Peer Help
plusnet blocks it all.. find a new isp that that doesnt block.
Peer2Peer Help
kk cheers
Slick
Peer2Peer Help
they use a program to cap you on certian traffic
Peer2Peer Help
I usually only get a decent download rate at about 2-3am until about midday then its 8-12kb/s for the rest of the time but completely unlimited on http or ftp.
Slick
Peer2Peer Help
if you are going to dl etc try and schedule for midnight to 4pm otherwise it will be capped
Peer2Peer Help
I do usually thats why I said from 2-3am till midday, but after midday its like I'm on dialup.
To be honest on p2p I never reach maximum at any time usually maxing out at 80kb/s instead of the 120kb/s my connection is capable of during http or ftp transfers.
