Peer to Peer
Peer to Peer
I have recently connected to ADSL via a router connection and appear to be experiencing problems in downloading using Morpheus, WinMX etc.
The search facility is fine but downloads appear to timeout. I have not gone into deapth in router configuration yet, I was just wondering if there is a general problem with this type of application and connectiopn via router.
1 REPLY
RE: Peer to Peer
My guess is that your problem is probably with the application i.e.Morpheus rather than your router. If there was a problem with the router it might be that you need to enable a specific port for use by Morpheus I would check with who ever has created Morpheus which ports it requires. You might find that the router needs a specific port inorder for Morpheus to allow inbound downloads,etc.
