PHP include function doesn't work
Does anyone out there use the PHP include, required functions.
I have a script that include two other files, a header and a footer. Evrything from the main php page is visable. The header and footer are missing.
Is this a limitation with the forcenine site or am I missing something?Huh
1 REPLY
Have you checked the paths are correct?
Including files should work, one problem though is that due to display_errors being off, if the include line has an error, you don't actually get to see the error message.
Could you post a small example of what is not working?
