PHP data to Javascript?
Hey all,
I need to get some info from PHP (CGI server) to a DHTML/Javascript file on the regular server. Everything I have tried has failed due to the seperate servers. The only option I have left is appending the data to the url which I really don't want to do.
Any suggestions?
RE: PHP data to Javascript?
How about a php script that returns some javascript
code which sets passes the data you want..
Example
test.php on crofters
$data_from_crofters = 'Howdy!';
echo 'var your_data="'.$data_from_crofters.'";';
then in test.html on homepages.force9.net include
<SCRIPT language="JavaScript" src="http://cgi.username.force9.co.uk/test.php">
<SCRIPT language="JavaScript">
document.write(your_data);
</SCRIPT>
May work, may not. Just an idea.
Allan
sorry. forgot the </SCRIPT> on the end there.
<SCRIPT language="JavaScript" src="http://cgi.username.force9.co.uk/test.php"> </SCRIPT>
