PHP & Dreamweaver MX
I am trying to use Dreamweaver MX to create my website. When it tries to connect to the database I get a "permission denied" error.
The only info I have about the mySQL server is that it is called rumpus. The help file says to enter an IP address or Server name.
Any one know what I'm doing wrong?
Hi
Your best bet is to develop your application in PHP on your machine and then when you are sure it is working, to upload it to your web space. DreamWeaver is great but it is best to work locally until you are sure everything is okay. Then you know what is the fault of your application and what is down to server constraints / problems.
Your post is quite old so I don't know if this helps!
Les
Ianwild
Yeah, apologies for the late help.
FYI, "rumpus" has an IP address of 212.159.3.4.
Regards,
Not a problem, more a word of appreciation. For some time I have been trying to connect to the MySQL server from MySQLfront on my own machine. The ip address supplied by Ian Wilde was the missing link. Now it works!
