PHP XML and XSLT on Force9 CGI area
Could anyone help me with this query?
I am using the CGI domain to use PHP for my site. The PHP is for processing XML. Problem is that I am trying to get a XSLT stylesheet working with my XML file and I get nothing.
I was wondering if someone could tell me if the PHP on Force9 has XML support enabled? If not would this be something that Force9 could enable?
Joe
Take a look at http://cgi.force9.net/phpinfo.php
There's a section on XML, which says:
    XML Support Active
    XML Namespace Support Active
    EXPAT Version 1.95.2
You may find information in the tutorials Common PHP Problems and CGI/Shell Server Basics helps you solve your problem.
Thanks for that. I had a look - although XML is supported XSLT is not. Force9 say that they will be upgrading to enable this in the next few months. Until then I will have to find some other web space!
XSLT is supported and working on Force 9.
I have it working myself.
XSLT is XML by the way !!
Martin
