PC cases
PC cases
Hi all...
Anyone know of a company that produces an ATX form factor sized PC case with handles on top - like the Apple G4 PowerMac ??
I move my PC about quite a lot ('bout time I bought a laptop, but haven't seen a dual Athlon one yet !) and it would be really useful to have a case with handles. I have seen one with a single handle on top, but it looked like a bit of an afterthought... nowhere near as sexy as the Apple ones.
There are loads of really neat cases around (Cooler master, Lian etc) but none of them have handles.
Cheers,
Daniel
Cheesy
RE: PC cases
Not seen one with more than one handle fitted but try http://www.coolcasemods.com as they do some cool modding equipment including handles and a modding service if you don't fancy having a go yourself! Good luck.
RE: PC cases
Cheers, mate.
Daniel.
RE: PC cases
You might want to check out www.spotoncomputers.co.uk i know they had some in last time i worked there.
hope this helps you out
