Odd connection problem
MadBob
Yesterday I had a very strange connection problem, I could get online from my LAN but not from the actual Internet Connection Server itself, anyway after a lot of searching I finally found out something I had installed had altered my DNS settings on my DSL connection! (I always have NAV and MaCafee Firewall running)
but now I have another problem which I am assuming is related to the same problem as it has started after a reboot, I have a BSOD (Win2k Server) that tells me a driver has tried to corrupt the stack, but whereas I usually get a driver name there is nothing, I have done all the usual MSconfig selective start-up and I can boot in safe mode with networking, but I cannot find the driver,
I have uninstalled everything from the last few weeks and used the Windows 2k CD to do Recovery check and ran sfc.exe /scannow to check for original drivers,
what I need is a utility that will log everything as i boot and log the names so I can find out which driver is shafting me, I have doen the windows Bootlogging but it isn't telling me which driver is corrupt, only the loaded or not loaded ones from the selective startup,
if anyone knows of a good logging util please let me know
Cheers.
What you said about mysterious DNS changes rang a bell when I was reading this article on theregister.co.uk - http://www.theregister.co.uk/content/56/33187.html - to quote the article,
This Trojan is responsible for recent reports of strange DNS changes on systems as recently reported on NTBUGTRAQ
Dunno, but it might be that you've got a little trojan fiddling with your machine. If so, tauscan (http://www.agnitum.com/products/tauscan/) is free for 30 days and seems to perform quite well in rooting out the little chaps.
Jon.
MadBob
The driver problem was a clash in Win2k between NAV and Verifier (from run prompt) if you try to verify NAV drivers at startup it crashes your system, a known problem read here and one that I fixed by excluding the NAV drivers from the startup verifier.
still looking into the DNS change but it was probably a script from a web browse, and I am up to date with NAV and all my Win2k patches so theres sod all else I can do until a better patch comes out.[/url]
Ah ok, there wasn't much thinking behind my suggestion other than you'd had a DNS change and there's a new trojan wot does that... Shockedops:
Verifier's a new one on me - never seen that before. I just brought it up and apparently I'm not verifying anything at the moment - what benefits do you get from verifying drivers at startup, apart from hanging NAV? :lol:
MadBob
Symantec I did have an attack and had to edit my registry and hosts file to get rid, the verifier does what it says on the tin, it verifies your drivers against a known to make sure they are not causing problems, unfortunately the NAV causes a problem when verified O_o
its an easy one to spot (the trojan) as Google stops working.
Ah, great, glad you managed to get it sorted. Damn wooden horses!
I've don't remember ever having any problems caused by corrupt/conflicting drivers, although I may have done and not figured out that this was the problem before taking some other action - reinstalling a service pack for instance, or junking cheap soundcards and installing Audigy :lol: Interesting tool though.
