ONSPEED
ONSPEED
Anyone else had experience of the accelerator - ONSPEED? I have been using it without too many hitches now for some 2 years. It's not perfect (it occassionally messes up and has to be re-installed - a two second job), but it combines with F9 well and basically it helps to take the frustration out of a less-than-2mb Broadband connection. Overall - quite pleased with result. What do others think?
Peter.
astarsolutions
ONSPEED
I have wondered about that for a while; I couldn't see it having any real benefit on a broadband connection.
Do you notice a difference, i.e. if you turn it off can you see the difference?
ONSPEED
Yes, you notice the difference - particularly with the basic Broadband speed going up and down like a yo-yo! (I am getting well below 1mb one day and 2.3 the next.) I feel that Onspeed allows me to put up with this without getting too frustrated! The amount of acceleration you choose (against the slight loss of image quality) is user defined and very easily regulated. May not be for everyone's taste, but it works well for me. Peter.
