Number of Connections to Mysql
I need to know the number of connections that can be made to a Mysql database using php can anyone advise as ive been told that the maximum default is set to 150
Does this mean that you can only have 150 users access a database at any one time how do you get past this if this is the case
Please could you supply an example of code
Many thanks
Mark Harrington email mark@harrington.force9.co.uk
1 REPLY
if you dont use persistent connections it shouldn't be a problem
