Not really about ADSL but then again its part of the package
Marteknet
Can anyone here advise me on problems with mysql-adim on the protal as support from Force9 is a joke (a bad joke).
I cant even add new rows to tables from the mysql-admin page on the portal and when i asked support they said nothing at all, just advised me to post a question here dispite me having sent them loads of details and screendumps about the error i keep getting.
Can any kind person help before i lose it completly.
Thanks in advance Peter
RE: Not really about ADSL but then again its part of the pac
Hi Peter,
> Dont loose it completely mate check this out! (hope this might offer some answers?).http://www.mysql.com/documentation/
> Hi Peter,
Hi Peter,
I think you have to be fairly familar with databases to succesfully understand how to design,configure get the best from this kind
feature.
have you had a look at the F9 tutorial on the portal
it would give you alot of useful stuff. There is also "Types of Help" on the same support pages.
See the following F9 potal link:-
http://portal.f9.net.uk/tools.html?JZu1oo1alTX%2FP11Oxeko58oaEX8qZYIjPE2cn5IWD6cCSXr48aD%2FLA%3D%3D
Marteknet
> > Hi Peter,
> Hi Peter,
> feature.
Sorry I think you misunderstand i have had the data base running for quite a few daya without problums. my code is ok. the problem is on the portal inthe mysql-admin found in the my tools dropdown menu.
when i use the data maintainace page and try to add a new row of data the gui just says there is an INTERNAL ERROR and will not accept any new data.
> > > Hi Peter,
> > Hi Peter,
> > feature.
YEP! definately crossed wires! my apologues. I now understand your problem. Yes! I would agree with you it does sound like a portal code level problem, especially if it's saying "Internal Error" Yes you are right to point this out to F9 support, its exactly what I would have done myself. I only hope F9 can pick it up and actually track down the issue and resolve it for you? I wish you luck!!.
