New CGI & OScommerce
Trying to migrate this to the new platform!
I've modded all dir.. to 750 & all files to 740. The install kicks in, enter sql details, user etc.. & then I get:
SQL file does not exist: /files/home2/********/*********./supermarket/install/sql/loaded_v615.sql
I've tried remodding the file even give it full 777 but ziltch.
Anybody cracked this?
Pnoneguy
well, is that the path the file is actually in?
Assuming you've blanked out your username, twice, then it looks wrong.
Can't be any other. I've FTP'd the files to the cgi-bin folder (sub folder supermarket). The way I understand it, the install script picks up automatically where it's @ and configures itself.
Where else can I put it?
Cheerz
Phoneguy
If the *** is your username twice, then you need to delete one of them, as there should only be one there.
I understand what you are saying, but I have no control over that!. The Script picks up it's location automatically.
I installed this on the old platform in exactly the same way with no issues.
Do I have to keep the folder "supermarket" under the cgi-bin or can it go on the same level?
phoneguy
If its perl scripts, it really needs to go underneath the cgi-bin dir.
I can see where the problem is occuring - it was fixed for PHP during Beta Testing, but appearently not for Perl.
Thanx csogilvie, but does this mean I can't set it up 4 the time being?Huh
Well I've got it working but I'm not very happy !! Thanx for the support from CS (NOT).
I had to download my existing store and upload to the new server, locating the folder at the same level as cgi-bin, to work. If I nest it under the cgi-bin folder it WILL NOT WORK.
Obviuosly the config files need editing for the new path.
Why is it F9 have set up a new server and CS are not active in this forum?
