Networking bandwidth help
I'm just about to get XBox live and have hub/router etc ready.
But when I'm playing games I don't want anyone who is using the other 2 PC's to take up too much of my bandwidth otherwise I'll end up getting lag..
Is there anyway to limit bandwidth a PC uses?
RE: Networking bandwidth help
You say you have a hub and router what speed are they 10 or 100.
If the pc's are running XP you can set the bandwidth with QOS.
Some expensive router allow you to do this using QOS as well.
I installed QoS, and the communication with the router went down.
After I've installed it, how do I configure it?
chino
I would try http://www.microsoft.com
cUnDaLl
Always go to the source!
