Network settings using a BT 240 Router & W2K Server
Hi All,
Posting this a 2nd time as probably posted originally in wrong Forum!
Can anyone help??
Changing over from BT ADSL with a BT 5681 Router to F9 with a BT 240 Router and having a mare trying to get the thing working.
We are running W2K Server with 2 Nic cards, ADSL in from Router, LAN out to multiport switch with 20+ PC's connected. Tried to setup 192.168.x.x network with Router running DHCP, had server seeing Web at one point, but not PC's, then lost the plot.
Then tried to setup for 10.x.x.x network as the old router was working with this and hoped that less settings would need changing on server, but things just got worse. Also the Server is running MS ISA, so don't know if that can [censored] it up.
So basically, any one know what IP & DNS etc settings I should have set on the two Nic cards on the Server and any other advice would be so gratefully received!
Cheers, Phil.
