Network IP ads
zpeterk
Network IP ads
I have 3 pcs(All win2k)a router and 2 print servers on a network. Is there an way to look to see what IPs there are using when they are using DHCP asigned by a router) or is it better to give them fixed IPs
RE: Network IP ads
The easiest way is to open a dos window and type in IPconfig
This will show you your network settings.
Bill
zpeterk
RE: Network IP ads
> Bill
How would I see all the IPs from one machine?
RE: Network IP ads
You'd need to look at the dhcp assignment table on the router... it will differ from router to router on haw to do this.. maybe telnet.. maybe web.. my SpeedTouch allows web access for example. I'm afraid you'll have to red the manual!
RE: Network IP ads
RE: Network IP ads
If you want to see the ip's then its best to have fixed ips.
There is always a chance that someone could break into your network and with a dhcp server they will get a ip so it make sit easy. With a fixed ip its easier to see what everyone is doing as they will always be the same ip.
Fixes: 9
RE: Network IP ads
From a DOS box ping each machine in turn using it's name.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
