Netgear DG834GT Modem Router Config
Hi
Anyone now how to config this router to work with force9??, i can get it up and connected but it keeps dropping the connection and i have to reboot the router to get it to reconnect again...not exactly sure what some of the settings should be. Hav reverted back to my voyager 105 or now
Ta
Nick
Ive got a belkin router and thatt works fine, so I'm not sure dude.
Whats happening when it drops the connection? Does the router remain synched, does the ADSL / Link light remain green and constant?
During initial config there is an option to test your settings, below the page where you configure you username and password. When you select "Test" does the screen throw up any errors.
Additionally there is a router status tab under the maintenance options. What does that display once connected?
