Net::POP3
Net::POP3
Is there a way of finding if a module is installed on cofters please? I am specifically looking for Net:TongueOP3.
Cheers
Mark
Net::POP3
http://cgi.force9.net/cgi-bin/perlinfo.cgi?action=60 has a list. Net:TongueOP3 is there... however, you can also do the following at a Command Prompt?
[csogilvie@cgi05 csogilvie]$ perl -e "use Net:TongueOP3";
[csogilvie@cgi05 csogilvie]$ perl -e "use Net:TongueOP";
Can't locate Net/POP.pm in @INC (@INC contains: /usr/local/lib/perl5/site_perl/5.8.2/mach /usr/local/lib/perl5/site_perl/5.8.2 /usr/local/lib/perl5/site_perl/5.6.1 /usr/local/lib/perl5/site_perl/5.005 /usr/local/lib/perl5/site_perl /usr/local/lib/perl5/5.8.2/BSDPAN /usr/local/lib/perl5/5.8.2/mach /usr/local/lib/perl5/5.8.2 .) at -e line 1.
BEGIN failed--compilation aborted at -e line 1.
Net::POP3
Sorry, being a bit of a thickie, do I take that to mean yes?
Mark
Net::POP3
Yes.
Net::POP3
Thanks Smiley
