NAT
NAT
NAT i know is a way your router uses multipal I.P> and sorts them to one to the server problem is i cant hoste and play multi player games no more? any one know of a way round this
:roll:
1 REPLY
NAT
Sure you need to forward the ports used by the game to your internal IP, try doing a search on google for game hosting & port forwarding for the game you are playing!
I had the same problem, but with netmeeting, slightly different but similar principle! It's all 'port forwarding'.
Hope this helps!
