NAT or NO-NAT
NAT or NO-NAT
Ive just ordered a Self Install ADSL Package, and was wondering if the NO-NAT option comes at an extra cost.
Second question,
I am hoping to VPN in to my office's network, I take it this would be possible with an ADSL router?
Many Thanks
RE: NAT or NO-NAT
> Second question,
Yes, if you buy a router that supports it - people have reported problems with some models. Check in the spec that VPN is supported, or ask on the uk.telecom.broadband newsgroup & the adslguide.org.uk discussion forum.
RE: NAT or NO-NAT
> > Second question,
Works fine for me, using a D-Link DSL-504
