MySQL scripts
MySQL scripts
I'm developing a gallery application with PHP/MySQL on Plusnet. Can anybody tell me if I can develop the database and application locally and then run the MySQL scripts to recreate the database and data on the Plusnet CGI server thus avoiding hours online entering data via phpMySQLAdmin? If so, how?
Any help greatly appreciated.
Jonathan Attree
MySQL scripts
as u are developing on ur local comp i presume u have apache,mysql and php installed so we'll skip that.
The way i would do it is install phpmyadmin on ur machine,export the database, then use phpmyadmin on the FOL server and import the database.
Thats about as easy as i could do it, but some others may say different.
Hope this helps.
Platty
phpmyadmin
Thanks for the reply.
Where can I get phpmyadmin?
Jonathan Attree
MySQL scripts
MySQL scripts
Thanks very much. It all works a treat.
Jonathan Attree
