My Website Defaced
My Website Defaced
Hmm - I happend to check my website a few minutes ago and found it 'defaced' with the following...
"This site is defaced!!!
NeverEverNoSanity WebWorm generation 16!
Now luckily it was only a small portion of my site dealing with uploads, several html files in a folder had been overwritten - clearly an oversite on my part which I must fix. However while I was restoring some of the files the following dawned on me...
"Hang on, everytime I want to flippin place a file on my CGI area I have to access Crofters using my Dial up account (I use a different ISP for Bband access - no offense to F9, I just do)"
So how can this happen? Is the defacer an F9 member, is there a virus on F9 servers or is it something else?
C.
tony2007
My Website Defaced
this happened some time ago
You might like to see this thread relating to your concerns:
http://portal.f9.net.uk/central/forums/viewtopic.php?t=4284
Sad
My Website Defaced
Thanks for that - I completely missed that thread, along as the auto-email from support mentioning the problem on the 21st! Must of been the build up to xmas and all that.
Ta.
C.
