Multiple Non-NAT Static IP's
Are multiple static ip's (at least 2) that are non NAT available on force9? If so how do I go about setting it up
Cheers
Rich
You can get multiple static IP's, raise a ticket.
What do you mean by Non Nat? I thought NAT was generally performed by routers/firewalls.
There used to be confusion over this sort of thing when ADSL first started up, BT would claim NAT and non-NAT on their packages, im still not 100% sure what they were on about. I believe this is where the confusion stems from though.
Of course any REAL ISP who gives you IP addresses will give you proper public IPs not private network ones. Maybe BT DID cut corners back then in putting cheaper users behind a NAT instead of ON the Internet, who knows, but im pretty sure nobody does now - would be rather useless for remote access though I guess thats why they did it.
