Most Help Useful
Most Help Useful
I found that going on to paltalk as a normal user then going on to Pc and computers section or groups then pick a tech you have about 8 to choose from so they may know other things or may not know your problem so just go to different rooms they can help you thou http://www.paltalk.com
RE: Most Help Useful
I found by not installing paltalk you will avoid infecting your PC with spy and ad ware, you will not be troubled by a program that places files all over your system, resists attempts to be shut down and does not uninstall cleanly.
RE:
A most enlightening thread.
RE: RE:
Glad to be of help Smiley
RE: RE:
What happened?
Did you just post blank values, posted value but the didn't show or cancle the request mid-transit?
RE: RE:
> What happened?
don't know what happened
Juggs are you sure you're not refering to Kazaa??
> Jugs, are you sure you're not refering to Kazaa?
Dead sure, paltalk is a pain in the rear.
Ought to try Spybot (free) an excellent programme:
http://security.kolla.de/index.php?lang=en&page=news
Now used it for a month and am converted to it.
