Message / Bulletin / Chat
Can anyone suggest how i set up a simple Chat/message/bulletin board for my website
www.blackheathcc.com
it is so that members can communicate, etc
all basic help greatly appreciated
Blackheath Cricket
RE: Message / Bulletin / Chat
> Blackheath Cricket
PHPBB
It works really well with F9, and is easy to set up.
www.phpbb.com
ikonboard is also pretty easy to set up.
Mark
i gave up on trying to get phpbb to work because i couldnt get the php scripts to work!
PHPBB works well (as you should be able to see!) but it isn't very good IMHO. At the moment, the "top dog" in my books is Invision Power Board.
Thomas
See task's replies in this What's the difference between CGI and MySQL? for a way to setup phpbb.
Neil
YABB (http://www.yabbforum.com) is pretty good and comes with an installer, similar to Ikonboard. If you want a really simple board go to: http://nms-cgi.sourceforge.net/ and take a look at their script.
Mark
Neil
Or even better.... the Help installing PHPBB FAQ! Smiley
Thomas
Shockedops: And I 'should' know better!!
Neil
Thomas
I can heartily second that. Its so simple to set up and use. Check it out at www.global-lifeline.co.uk
