MSN Messenger 6.2 transfer speed
whenever i try to transfer a large file to a friend over msn messenger it comes up saying "IF YOU ARE EXPERIENCING SLOW TRANSFER SPEEDS CLICK HERE" So I clicked and it basically said to increase speed (from my current 3kbs) I should open up as many ports available on my router. Anyone any idea how to open up ports?
(apparently between 6891 and 6900. )
by the way i'm using the router that is supplied with f9
come on someone must know
well it took me 30 seconds on google typed "MSN Messenger Ports" for my search and voila:-
http://www.anetforums.com/posts.aspx?ThreadIndex=18752
now if you had done this days ago yourself you would already have the answer you needed[
ummm
yeah that tells me which ports to open not how to open them. i have no idea about how routers work so bare with my absolute and pure ignorance
Which router (make and model) are you using? What about a firewall? -- are you running one (eg a software firewall, distinct from the router), and if so, which?
okay
I'm using the sar-130 router that was supplied from f9. I'm not using any firewall and that includes the inbuilt one no Windows XP which I have turned off
