Link to Script
Link to Script
I have written a server side include script for my site and put it in my cgi-bin as header.php.
What path address do I write to link to it from my web page?
Link to Script
Firstly, your PHP script should not be in the cgi-bin directory, as this no longer works. Secondly, if you are trying to include it from the homepages (www.) server, then it won't work either.
Link to Script
How do I get the script to work? Where do I upload the script and how do I link to it from my web page?
Thank-you for quick response
Link to Script
You need to upload it to hte CGI server, outwith the cgi-bin directory.
Link to Script
Done as requested, I have now uploaded the file outside my cgi-bin directory.
What now is the path from my web page to the file so as to link the two?
Link to Script
You can't use SSI - but the url is likely to be http://cgi.username.force9.co.uk/file.php
Link to Script
The path address is correct but alas not working.
Won't SSI scripts work on F9?
