Line says 2mb, speed tests say 512...
Hi, I got my line regraded today (thanks FOL), but I've run loads of speed tests from lots of different sites, and my average download speed is about 556kbs.. Is my account set correctly?
Thanks in advance,
Nic
1 REPLY
Unthrottling the line Ivan
Hi Nic,
You will need to contact FOL support either by phone or by openning a support ticket (slower by ticket) you line will need to be unthrottled for you to get the full 2MB speeds. You will also need to do a reboot of your kit so that the upgrade takes full effect. The unthrottling by FOL can usually be done very quickly for users once the line has been upgraded.
Ivan
F9 FOL Forum Moderator
F9 Broadband Premier 2MB User
Your Forum, Make Your Voice Count!
