Lindows....
chino
Lindows....
I am on xp pro...
and i am thinking of moving to lindows..
What does everyone think of lindows?
cUnDaLl
p.s. Longhorn is out...
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: Lindows....
Dont swap get Vmware or the other emulator and then you can run both at the same time.
If you never tried these emulators there great they boot up with their own bios in a xp window you format the drive which is actual a file install any os like os/2 dos nt4 lindows unix linux and uncle tom cobble and all. Its the only way to go as there is no formating of hd or anything.
I put lindows on not impressed just another linux.
> I am on xp pro...
> Thanks
> cUnDaLl
chino
RE: Lindows....
Thanks i will check it out...
I know lindows is just another form of linux but that means it's stable but it will run M$ appz too...
cUnDaLl
