Just a test
Phantom_Flan_Fl
Just a test
Want to see if image posting works.
Ianwild
Just a test
Awwwwwwwww!!!
Bit of a dangerous feature that one - Try to keep 'em to reasonable size won't you :roll:
Phantom_Flan_Fl
Just a test
That's always the risk. Is there no way to restrict image sizes??
I suppose if it gets abused it should be withdrawn.
Are there restrictions on sig and avatar sizesHuh
Just a test
Cant see a restriction on sigs only avatars max H/W 80*80 file size <=6kb
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Phantom_Flan_Fl
Just a test
I've seen the restriction on avatar sizes since the post I made.
Just couldn't be bothered reading the FAQ's and that Ian Wild bloke is such a helpful chap. :lol: :lol:
Just a test
as far as i can see there is no physical restriction on avatar and sigs as they can be links to images on the web. There is a guideline restriction though for avatars that people should stick to
Just a test
Look in your profile settings for the avatar restrictions, needs to be added to the faq as well
Displays a small graphic image below your details in posts. Only one image can be displayed at a time, its width can be no greater than 80 pixels, the height no greater than 80 pixels, and the file size no more than 6 KB
Phantom_Flan_Fl
Just a test
I know in the past on other boards, if you try to have a larger image it tells you you have exceeded the limit and won't let you have it.
Don't know if that's the case here.
Phantom_Flan_Fl
Just a test
Where in Scotland you from adp?Huh
Just a test
Classified :shock:
rikmoncur
Just a test
Cheesy I like this - about time too!
Phantom_Flan_Fl
Just a test
Just wondering as I'm originally from Falkirk.
Just a test
test Cheesy Cheesy Cheesy
Just a test
Well I'm from everywhere, I've/family has moved about a lot. Currently in midgey hell, aka Highlands
Just a test
Seeing if can do an avatar!
