IP blocks
CallumW
IP blocks
Hi
I was automatically given a block of 4 static IP's - as well as my existing static IP. It caused problems as I have MX records pointing to my home emailserver (my rev DNS IP changed to the 1st IP in the block of 4)
What could I do with a block of 4IPs? (e.g. running my own DNS servers?)
Anyone already use them - and for what?
Ta
CW
pops1000uk
IP blocks
i wanna know the same?? my static ip changed too
IP blocks
On a block of 4 IPs with DNS, you will have to modify your zone file so it will connect to the mail relay on a timeout..
mail1.domain.com IN MX 5
mail2.domain.com IN MX 10
1.2.3.4 CNAME mail1.domain.com
5.6.7.8 CNAME mail2.domain.com
this will work by connecting to the first IP, refusing a connection, then connecting to the second one. The numbers 5 10 etc determine which site is a primary MX host. 5 has more priority than 10, 20 has more than 100 etc.
For web services, you could use round robin DNS or something like that.
I am not quite sure that kind of dns management force9 provide - whether they will add in an mx host, or a block of mx hosts to relay mail to you for example, but this would be the best way to do it without static ip addresses - just cover all eventualities.
Prolly best to speak to a member of F9 who manages the zone information for the domains.
CallumW
IP blocks
They said to post in the forum :p
IP blocks
hehe..
Well they manage the DNS information ... unless you use something like dydns.
Re: IP blocks
Ignore the ones you don't need.
These day's you can do a shed load off one IP providing you understand host headers and DNS. Extra IP's can be handy if you're running multiple published web services and use IP sec or a DMZ to limit access.
