I think i'm going crazy. Aaaagh!!
#1. I have been looking through Putty at my cgi paths. It used to be /files/local/home/didit then the folder names after. If I put this in now, I receive a -bash: /files/local/home/didit: No such file or directory. Where has it suddenly gone? The scripts I have using that path appear to be working fine (except one which is on another discussion).
HELP :!: :!: :!: What is going on?
Cheers
Mark
1 REPLY
Well b*gger me. If the paths haven't changed!!! Instead of /files/local/home/didit, it is now /files/home/didit. I suppose i'll have to go and change the paths to my other scripts before they too stop working Sad
Regards
Mark
