How to send mail when logged on with GPRS
When I log onto the internet with my iPAQ and mobile phone using Vodafone GPRS I can retrieve my mail from PlusNet, but it won't send.
Has anyone made this work ? How ?
Regards David
1 REPLY
RE: How to send mail when logged on with GPRS
> Regards David
It may be that its plus nets security settings on the relay server. Most ISP's only allow relaying for clients that are within a certain ip range. And the only way of getting that ip is by dialing into them / using a service (like adsl) direct into plus net.
Your ip will be different as you going through vodaphones internet service (as your using gprs), if you dialed direct then you wouldnt have a problem. To send messages im sure vodafone have a smtp server you can use.
HTH
Gary
