How can i 'turn off' my static IP address?
Is there any way I can turn off my static IP adress I receive as part of my ADSL package?
Nope. If you are worried about the rDNS of username.free-online.co.uk, then you can get it changed to be either
static_ip.free-online.co.uk
host.domain.ext (if Free-Online have the NS records for the domain and its hosted on your account)
The route for this is:
link:Contact Us then New Query and:
Technical Support >> Static IP / Reverse DNS Setup >> Change my Reverse DNS (PTR) configuration
and explain what you want.
To be honest i thought u were wrong on this one csogilvie but i've just been through the my connection setting and you can no longer change from a static IP but you did used to be able to.
To FOL: why isn't this possible any more? I'm quite happy with a static IP as it servers my needs but it is a security risk for ADSL users and some do not want this risk. I.E. hacked irc bots
Platty
As I understand it, ADSL users have never had a Static IP.
Considering I've had a static IP for over 2 years i'd like to contest that, since the day my adsl was installed i've had a static IP, and no i don't mean reverse DNS.
Current Status : You are now using a static IP address
Static IP: 212.56.101.**
Netmask: 255.255.255.255
That is from the connection settings part of the portal.
Last 2 digits removed from ip addy because of paranoia, lol
Platty
Damn... it really was a bad night last night!!
That post was meant to say "As I understand it, ADSL users have never had a dynmaic IP."
As far as i'm aware all adsl comes with a static ip addy, well mine did at least, but there was an option in "my Connection" to disable this and have a dynamic IP. It said if you disable static IP you will not recieve the same IP address if you decide to return to a static IP, or words to that effect, but the option was there.
Platty
I guess its been removed then... I know its possible on other account types to go back to Dynamic but not ADSL.
Thanks for your help guys, but I guess there is no way to go back to a dynamic IP then.
Yep - ADSL does not offer a Dynamic IP. I think it is/was being looked at though.
Ok, thanks for all your help with this anyway!
Surely, Colin / "csogilvie" was -- strictly speaking -- correct to say the address is dynamic, in that it is assigned by DHCP. A "static" address is one which is assigned manually without the use of DHCP.
RFC 2131[/url] para 1"]DHCP supports three mechanisms for IP address allocation. In "automatic allocation", DHCP assigns a permanent IP address to a client. In "dynamic allocation", DHCP assigns an IP address to a client for a limited period of time (or until the client explicitly relinquishes the address). In "manual allocation", a client's IP address is assigned by the network administrator, and DHCP is used simply to convey the assigned address to the client. A particular network will use one or more of these mechanisms, depending on the policies of the network administrator.
IE no such thing as "static assignment" in DHCP.
RFC 2131[/url] para 1.6"]
  • DHCP must coexist with statically configured, non-participating hosts and with existing network protocol implementations.
    DHCP must:
  • Retain DHCP client configuration across DHCP client reboot. A DHCP client should, whenever possible, be assigned the same configuration parameters (e.g., network address) in response to each request,
  • Retain DHCP client configuration across server reboots, and, whenever possible, a DHCP client should be assigned the same configuration parameters despite restarts of the DHCP mechanism,
  • Support fixed or permanent allocation of configuration parameters to specific clients.
Thus, examination of the DHCP RFC would indicate that rigorous (and therefore unambiguous) terminology is that a "static" address is one allocated outside of DHCP and a "fixed" or "permanent" address is one assigned through DHCP, but the same address is assigned to a given host each time.
So, your address is a dynamic but "fixed" address, I say, not a "static" one!
