Host Website at home
Hi
I have registered a .co.uk domain name with Plusnet.
mydomain.co.uk. I would like to host this domain at home.
When i ping www.mydomain.co.uk it resolves to 212.159.8.1.
I have added an additional DNS entry
www.mydomain.co.uk a x.x.x.x (my ip)
and set domain hosting setting to other.
Does anyone know if I will need to do anything else?
My router is set to forward HTTP requests to my PC.
Thanks Inderpal
RE: Host Website at home
While I intend to do this myself, I havn't yet registered a domain.
From what I can make out, that is all you would need to do.
Note, you will likely find, that your router will not allow you to browse your site, due to the way TCP/IP works.
Aditionaly, you will find it may take up to 24 hours before it all becomes operational. THis is due to DNS cache expiring, and the +Net scripts doing there jobs.
I forgot to mention 212.159.8.1 is not my static IP.
212.159.8.1 is the IP for regd.plus.net
I set it around a week ago, so it has had enough to propogate its change.
HMMM.
I would say this topic is not releavant to this forum. If you wish to discuss matter that relate to your PlusNet account (And would like any assistance from Support) you should use the PlusNet forum.
Regards,
Ian Wild
PlusNet Customer Support
Perhaps more appropriate elsewhere but "Where you can discuss just about anything under the sun - well, almost!" ;-)
Sorry, my point was that if you had asked in the PlusNet forum I could have answered your question :-)
Regards,
Ian
