Help need with WHERE clause in form queries
Hey all you professional scripters can you help a newbie with a very frustrating problem?
I have a table on my database that contains details of members - having field names name, contacts, details, region.
I have a form on my website for visitors to seek for members by name. As they may not know the full name I am attempting to use LIKE in the folowing line
$resultID = mysql_query("SELECT name, contacts, details FROM pbfamembers WHERE search LIKE '%'", $linkID)
but I don't know what to put in after LIke - I know it has to have the percentage marks and single quotes but what goes in between?
Here is an example as a visitor would use it - I am looking for say John Williams but I am not sure if his first name is John and the field on the table contains both names, so in the text box which has the name ="search" I type in Williams
The result is that I get either all records or a rude message.
If I remove the WHERE clause the script works (albeit I get all records) so I guess it is the WHERE clause screwing me up.
I have tried varius options but nothing seems to work so if anyone can help me it would be wonderful cos it is driving me nuts
Gina
RE: Help need with WHERE clause in form queries
SELECT name, contacts, details FROM pbfamembers WHERE search LIKE '%$linkID'
should do the trick
Also that will only match ___$linkID, so if $linkID = an then scan, plan, an etc will be matched but not ant. If you want to return everything that contains $linkID you should use an extra % as such:
SELECT name, contacts, details FROM pbfamembers WHERE search LIKE '%$linkID%'
Also the field that you're LIKE matching must obviously exist in the table(s) you're querying.
> should do the trick
Big Al
Thanks for that but I think I have misled you a bit.
The variable $linkID is a declared variable that includes all my connection details (host, userId, password) and is nothing to do with the actual query. I just put it on the end of all my queries after the finishing " and it seems to work.
The actual select query runs like this
$resultID = mysql_query("SELECT name, contacts, details FROM pbfamembers WHERE name LIKE '%$search%'", (then the text linkID);
"name" is the right column name for that table and "search" is the name of the text box on the html form.
If I take the WHERE clause out and use = '$search' it works just fine ( I put in a very short name to test it!)
Sorry if you have been slaving away for nothing, but your help is appreciated.
Gina
Well that should work fine then, and don't worry there was no slaving away on my part. If you're stuck with SQL in general, you should have a look at the Language Reference chapter from the MYSQL manual available at http://www.mysql.com
Al you are a genius
I went and checked the html form and discovered that somewhere in my ramblings I had changed the text name to "search". I have now corrected my error, deleted all my temporary Internet files and wow it worked. Thank you so much for holding my hand.
On another matter I see you respond to the forums a lot and you also share my thoughts on the portal MySQL admin. I too have trouble putting data into one table I have created, and have no idea what I am doing wrong. I am cutting and pasting from a Excel spreadsheet at the moment But as I have 750 records to get in by the weekend, I would like a quicker way that works, without "internal errors" cropping up and no data saved.
I read in my MySQL manual that there is a very easy way of getting a text file into a table you have created but you need to use the command line interface for it. The syntax looks quite straightforward - I have a tab delimited text file the same name as a table I have created but I have one big problem - some of the fields have active links (email and website addresses mostly) Will these get destroyed during the import or do I tediously have to escape all the backslahes, and quotes?
Is this easy to use because I have never used it before and I am of a nervous dispostion.
But hey I have taken up enough of your time already -just ignore this geriatric novice programmer who should really be knitting socks for the grandchildren but programming keeps my brain alive.
Thanks again - very very much appreciated.
Gina
> Al you are a genius
> Gina
Gina,
I think I was the guy that spoke to you about doing this a while ago, I made the code and couldn't find your email address.
I hope this code comes out right, if not I will email it to you. This will take the tabbed file and create a table in a browser for you. All you have to do to get it into a MySQL database is add the MySQL connection code above this and add a command something like this just before the end of the loop
mysql_query(sqlString);
You must created the variable sqlString before (you can make it inside the braces if you want. the SQL string would be something like:
INSERT INTO dbasename SET (name, tel, details, branch) VALUES ('$name','$tel','$branch','$details')
then your done, just run this page at your cgi space on crofters or whichever server your on and the data will be in the table. I will happily help if I can.
cheers.
Chris.
------------------PHP CODE below--------------------
<table cellspacing="0" style='font-size:8pt;'>
$fname="PHPTEST.txt";
$fp=fopen($fname,"r") or die("Error found.");
$line = fgets($fp, 204Cool;
while(!feof($fp)) {
list($name,$tel,$details,$branch) = split( "\t", str_replace("\"\"", "'", $line), 4 );
print "<tr><td>";
print "$name";
print "</td><td bgcolor='#eeeeee'>";
print "$tel";
print "</td><td>";
print "$details";
print "$branch";
print "</td></tr>\n";
print "<tr bgcolor='silver'><td></td><td bgcolor='silver'></td><td></td><td bgcolor='silver'></td></tr>";
fclose($fp);
</table>
Chris
How wonderful to hear from you again! I see you are busy helping other people too.
I still have the PHPtest.txt you did for me adn I sent you a reply which you obviously never received.
I think you were changing emails at the time.
I thought I had mortally offended you adn you had given me up as a lost cause.
I actually said in that email - long time ago "thank you now what do I do?"
Anyway it is great to make contact again and any help you can offer is much appreciated. I will read your reply very closely and probably come back with questions if that is okay and then if I am brave enough have a go with some test records.
I really do not get on with the portal arrangement. I know I am probably doing something wrong but "internal error" means nothing although support did suggest I deleted all temporary Internet files.
The frustrating thing is that the other tables work well - it just doesn't seem to like these these bl**dy members
Hope to hear from you soon
My direct email address is gina@pbfa.org
> Gina
Gina
Gina....I have emailed your other account.
