Help me, trying to run two php programs from 1 database.
hi there,
jsut wondering if you guys can help me on a few problems.i am currently running a phpBB message board, at www.born4boarding.co.uk . Although i want to set up a Geeklog or PhpNuke "weblog" type system.
*The thing is i seem to have problems, trying to run the weblog (php-nuke) type program.
i get errors, i think it might be due to not knowing
# $prefix: Your Database table's prefix
# $user_prefix: Your Users' Database table's prefix (To share it)
# $dbtype: Your Database Server type. Supported servers are: MySQL, mSQL,
WHAT ARE THESEHuh
Although this is the probelm with installing my phpNuke system. I have a probelm of CHMOD-ing
http://cgi.arent.free-online.co.uk/geeklog/public_html/admin/install/check.php this will tell u the problems. This says these pages havn't been "chmoded" although they have in cuteftp. and that TELLS YOU IT HAS BEEN!? why won't the php reconise itHuh
cheers,, any help will be usfull
ben,
1 REPLY
RE: Help me, trying to run two php programs from 1 database.
Don't worry,
i have worked that out, but CAN U UPGRADE MY SQL ACCOUNT!Huh?!
to MySQL 3.23.54
cheers
ben
