Help Needed About Faxing
I downloaded Symantec's Winfax Pro today but I can't figure out how to set it up-it couldn't find the modem ,presumably because it's not a dialup and it wasn't on the list of modems .
Has anyone used any fax facilities from their pc using Broadband -can you help.
Stuart
RE: Help Needed About Faxing
I've never specifically tried to do this but I'm certain it won't work.
WinFax Pro uses the modem in exactly the same way as a fax machine (a fax machine basically has a 14k modem inside it). There are some web -> fax services around but they fill your fax with adverts. Can't think if an URL at this point!
> Stuart
Come on Boro!
http://www.waynessa.co.uk/boro.htm
I just decided to use Win Fax Pro and re-installed my dialup modem and it appears to work ok
Stuart
