Girlfriend > Wife need support
Ok I am sure everyone on here has probably seen and read this before.
However for good humor I thought I would point it out again for those more inexperienced among us.
Last year a friend of mine upgraded from Girlfriend 4.0 to Wife 1.0 and found that it's a memory hog leaving few system resources for other applications. He is also now noticing the Wife 1.0 is also spawning Child-processes which are further consuming valuable resources. No mention of this particular phenomenon was included in the product documentation, though other users have informed me that this is to be expected due to the nature of the application.
Not only that, Wife 1.0 installs itself so that it is always launched at system initialization where it can monitor all other system activity. Some applications such as PokerNite 10.3 , Bachelor Party 2.5, and Pubnite 7.0 are no longer able to run on the system at all, causing the system to lockup when launched (even though the apps worked fine before).
Wife 1.0 provides no installation options. Thus, the installation of undesired plug-ins such as Mother-in-law 55.8 and the Brother-in-law Beta is unavoidable. Also, system performance seems to diminish with each passing day.
Some features my friend would like to see in the upcoming Wife 2.0:
* A "don't remind me again" button.
* Minimize button.
* Ability to delete the "headache" file
* An install feature that provides an option to uninstall 2.0 version without loss loss of other system resources.
* An option to run the network driver in "promiscuous mode" allowing the the system's Hardware Probe feature to be much more useful/effective.
I myself wish I had decided to avoid all of the headaches associated with Wife 1.0 by sticking with Girlfriend 3.0 Even here, however, I have found many problems. Apparently you cannot install Girlfriend 4.0 on top of girlfriend 3.0. You must uninstall Girlfriend 3.0 first, otherwise the two versions of Girlfriend will have conflicts over shared use of the I/O port. Other users have told me that this is a long-standing problem that I should have been aware of. Guess that explains what happened to versions 1 and 2.
To make matters worse, the uninstall program for Girlfriend 3.0 doesn't work very well, leaving undesirable traces of the application in the system. Another identified problem is that all versions of Girlfriend have annoying little messages about the advantages of upgrading to Wife 1.0!
VIRUS ALERT
All users should be aware that Wife 1.0 has an undocumented bug. If you try to install Mistress 1.1 before uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself. Once that happens, Mistress 1.1 won't install and you will get an "insufficient resources" error message. To avoid the aforementioned bug, try installing Mistress 1.1 on a different system and " never" run any file transfer applications(such as Laplink) between the two systems.
FYI: Don't even think about a shared directory!!!!!!!!!
_____________________________________________________
Can you please advise me. I'm having some problems. I'm currently running the latest version of Girlfriend and I've been having some problems lately. I've been running the same version of DrinkingBuddies 1.0 all along as my primary application, and all the girlfriend releases have always conflicted with it. I hear that DrinkingBuddies won't crash if you run girlfriend in background mode with the sound turned off.
But I'm embarrassed to say I can't find the switch to turn the sound off. I just run them separately, and it works okay. Girlfriend also seems to have a problem coexisting with my Golf program, often trying to abort Golf with some sort of timing incompatibility. I probably should have stayed with girlfriend 1.0, but I thought I might see better performance with GirlFriend 2.0. After months of conflicts and other problems, I consulted a friend who has had experience with GirlFriend 2.0. He said that I probably didn't have enough cache to run girlfriend 2.0, and that eventually it would require a Token ring to run properly. He was right --- as soon as I purged my cache, it uninstalled itself. Shortly after that, I installed girlfriend 3.0 beta. All the bugs were supposed to be gone, but the first time I used it gave me a virus. I had to clean out my whole system and shut down for a while.
I very cautiously upgraded to girlfriend 4.0. This time I used a SCSI probe first and also installed a virus protection program. It worked okay for a while until I discovered that GirlFriend 1.0 was still in my system! Then I tried to run GirlFriend 1.0 again with GirlFriend 4.0 still installed, but GirlFriend 4.0 has a feature that I didn't know about that automatically senses the presence of any other version of girlfriend and communicates with it in some way, which results in the immediate removal of both versions! The version I have right now works pretty well, but there are still some problems.
Like all versions of girlfriend, it is written in some obscure language that I can't understand, much less reprogram. Frankly, I think there is too much attention paid to the look and feel rather than the desired functionality. Also, to get the best connections with your hardware, you usually have to use gold-plated contacts. And I've never liked how GirlFriend is totally "object-oriented". A year ago, a friend of mine upgraded his version of GirlFriend to GirlFriendPlus 1.0, which is a Terminate and Stay Resident version of GirlFriend. He discovered that GirlFriendPlus 1.0 expires within a year if you don't upgrade to Fiancee 1.0. So he did.
But soon after that, he had to upgrade to Wife 1.0, which he describes as a "huge resource hog". It has taken up all of his space, so he can't load anything else. One of the primary reasons that he upgraded to Wife 1.0 is that it came bundled with FreeSexPlus 1.0. Well, it turns out that the resource allocation module of Wife 1.0 sometimes prohibits access to FreesexPlus, particularly the new Plug-Ins he wanted to try. On top of that, Wife 1.0 must be running on a well warmed-up system before he can do anything. Although -he did not ask for it, Wife 1.0 came with MotherInLaw 1.0 which has an automatic pop-up feature that he can't turn off.
I told him to try installing Mistress 1.0, but he said that he heard if you try to run it without first uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself, Then Mistress 1.0 won't install anyway due to insufficient resources. Can you help?Huh
holdtight
It was so long ago Tom i think pubnite is now up to version 10.0 Wink
Yer I thought it was an age ago.
But for the benefit of the lesser experienced I thought it could be worth while pointing out the bugs and problems encountered previously Wink
Yep been there , done that, got the decree (and the overdraft) Sad
Now on wife 2.01 and have been for a long time so I don't think I'll be trying any more upgrades Cheesy
I am also suffering problems with Wife 1.0.
I have just caught her on Evans web site purchasing this bargain she found in the sale.
Link to screen shot
Chilly
Chilly it may just be that new glasses are required. Wink
LOL.
Running wife 1.0 but mine seems to have an added nag feature which can't be removed or turned off.
(Then again I'm a lazy sod of alot of it is probably justified Wink )
lol,
you tried reporting it as a bug?
Yep, the system promptly crashed and wouldn't let me access the io ports for a week.
Not to mention it appeared to transfer the headache program to me via a frying pan.
So I'd put a health warning note on the nag module:
"Any attempt to uninstall or ignore the nag module will result in the withdrawal of IO services and could cause the user to have an unfortunate encounter with a kitchen implement. Any attempt to install 'Overtime to avoid nag' will result in Wife1.0 buying more shoes. Attempting to limit access to shoeshop will result in the same issues as removing the nag module. Attempts to limit access to CreditCard3.0 will result in nag module running at a higher priority together with headache module permantely installed until access to CC3.0 is restored."
