Getting New Wireless MIMO router, is it ok?
javis check out your PC world in Sheffield and they'll have loads of the Belkin Pre-N (MIMO) Routers in stock, i wouldnt recommend buying it as you dont have ADSL i presume, get the one im getting, its will work with ADSL, if you do get a MIMO one!
soon i should be getting the DI-624M
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVUDLYZU93ygJVYKOhST9vhLPG3yV3oVIp8g6ltbNlwaaRp7D4sAmu5j3cf/...
with a DWL-G650M
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVUDLYZU93ygJVYKOhST9vhLPG3yV3oVIp8galtbNlwaaRp7D4sAmu5j3cf/...
and a DSL-300T to convert the router from cable/dsl to ADSL
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVUDLYZU93ygJVYKOhST9vhLPG3yV3oVox8kP98f8p8Nqtg7D06VHqqnHtB8...
and a PCMCIA to PCI adpator to use the DWL-G650M in my desktop!
http://www.solwise.co.uk/wireless-pci-slot-senao.htm
Is this set-up ok? I used to have a belkin pre-n router but then realised it doesnt work with ADSL unless you have an extra ADSL router with it.
Hi garytester,
I have to say that I think you would be better off buying a router with built in modem. If you like the D-Link hardware, you may want to look at buying the following package:
http://www.ebuyer.com/customer/products/index.html?rb=6662889380&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3...
and then all you need is a PCI adapter for your PC... cant really speak for PCI adapters, so the solwise may be fine. I have heard that you are best buying same brand wireless stuff, btu the reviews for D-Link are not very good for PCI, which is probably why you chose the solwise in the first place Wink Another one to consider with ok reviews....
http://www.ebuyer.com/customer/products/index.html?rb=6663132769&action=c2hvd19wcm9kdWN0X3Jldmlld3M=...
Hope that helps!!
Jarv
ive seen that one but i really need one with MIMO, for its speed and its coverage. in the past ive had a MIMO router and it was excellant and 54g one that came with BAD lag in games. i couldnt keep the belkin MIMO one cas it wasnt for ADSL.
aha this is where my experience ends! This is the first time I have heard of MIMO.
Have read about it and it looks good. Does it really have that much extra coverage at that speedHuh
Hell Yeah, something like 800% more coverage than 54g and 600% faster. It really is!
I used to play Battlefield Vietnam over the Belkin Pre-N (MIMO) i used to have and never lagged or jogged etc. at all. great piece of kit. I had serious lag on my old Belkin 54g. This was when i played a LAN game by the way.
Soon i will get the D-Link (MIMO) router which is ADSL compatible if you have a DSL-300T ethernet modem which i already have.
nice, will keep an eye out for that !
