Force9
Force9
Hello,
Is/are Force9 having problems?
(I don't seem to be able to bring up their site nor collect emails.)
Tim
RE: Force9
Good Morning,
Not that I am aware of. I can collect my email and view the portal.
What URL are you using?
Kind Regards
Duncan
| Duncan Scotland          Unmetered & ADSL solutions
| Senior Technical Consultant   for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ------- My Referrals - It pays to recommend PlusNet ---------
RE: Force9
Hello
Thanks for the response:
I've tried a few - just tried:
http://www.force9.net/ and, for my email, I'm using
mail.force9.net
relay.force9.net
Perhaps I've been dropped as a user?
RE: Force9
Just remembered that I'd upgraded my firewall to ZoneLabs Pro V3 - turned it off and it all worked again...
Wonder how I should set it as I could get to lots of sites but not all...
Sorry I troubled you!
Tim
RE: Force9
Just had a look at the email that came in via Force9 and found this:
Microsoft Customer,
this is the latest version of security update, the
"7 Mar 2002 Cumulative Patch" update which eliminates all
known security vulnerabilities affecting Internet Explorer and
MS Outlook/Express as well as six new vulnerabilities, and is
discussed in Microsoft Security Bulletin MS02-005. Install now to
protect your computer from these vulnerabilities, the most serious of which
could allow an attacker to run code on your computer.
This contains a virus and is the third one in a week from whoever this is!
Watch out!
Tim
RE: Force9
> Microsoft Customer,
> Watch out!
> Tim
Thanks for that. Just goes to show that you can't trust anything anymore. What will they think of next. Firewalls, viruscheckers .... I'll be cacooning my PC in a small room surrounded by a farraday cage and soundproofing next !!!!!!!!
RE: Force9
> Microsoft Customer,
> Watch out!
> Tim
Microsoft do not send out emails re security updates, to install an update either use auto update or go to www.microsft.com and go from there!
